128GB SanDisk Monolithic SD Card
Discuss the ins and outs of USB thumb drive data recovery
italyassistance
Re: 128GB SanDisk Monolithic SD Card
Post by italyassistance »
So the spiderboard can be good for monolithic ones that have large pads but for everything else it is much more useful to solder, will they improve it? or will they get rid of it?
I suspect that they will just leave it as is.
Datalabs (Instagram) came up with their version of a spider board for those who like to use wires rather than the needles.
italyassistance
Returning to this topic, I'm starting to use the soldering method more and more, on the SD and MSD with distant pads, the tin balls, the lacquered copper wire and the rosin, with a little patience I can do a decent job, but on the MSD with very close pads, it's often a nightmare, suggestions on how to solder very close pads without the nearby one melting and then having to start again?
italyassistance
lcoughey wrote: Fri Oct 18, 2024 2:08 pm I suspect that they will just leave it as is.
ddrecovery
Post by ddrecovery »
italyassistance wrote: Thu May 29, 2025 1:30 pm Returning to this topic, I'm starting to use the soldering method more and more, on the SD and MSD with distant pads, the tin balls, the lacquered copper wire and the rosin, with a little patience I can do a decent job, but on the MSD with very close pads, it's often a nightmare, suggestions on how to solder very close pads without the nearby one melting and then having to start again?
Only advice I can give you is to use the right equipment and practice, practice, practice.
italyassistance
ddrecovery wrote: Thu May 29, 2025 2:04 pm
i have this jbc
with nano tips, any advice on what temperature to set when I'm welding very close together?
ddrecovery
italyassistance wrote: Thu May 29, 2025 2:07 pm
i have this jbc
Can't see that picture for some reason, but I use 650f.
italyassistance
ddrecovery wrote: Thu May 29, 2025 2:20 pm
i have this jbc
JBC CD-2SQF
What temperature do you set it to to solder the wires onto the solder balls?
ddrecovery
italyassistance wrote: Thu May 29, 2025 2:29 pm
i have this jbc
JBC CD-2SQF
650f.
italyassistance
ddrecovery wrote: Thu May 29, 2025 2:35 pm
JBC CD-2SQF
650f.
650 ° fahrenheit? sorry im in italy here we use celsius grades 650F
(650 °F - 32) × 5/9 = 343,333 °C
