MRT USB to SATA probe board
I like the USB terminal and it's ability to read/write modified ROM.
I don't see any mention of needing to remove caps from the patient USB board, which is a nice win, if true.
Re: MRT USB to SATA probe board
A response from MRT about models and very resonable price.
IIUC, the entire drive is powered through a pogo pin. I would prefer a more solid power connection. I guess this could easily be added, though.
I recall an earlier design where MRT mistakenly used a switch IC rather than a SATA redriver. This effectively made their adaptor little more than a placebo. I would be interested in analysing the chips in this latest design. It would be very embarrassing if MRT were to make the same mistake again.
fzabkar wrote: Tue Aug 01, 2023 1:24 am IIUC, the entire drive is powered through a pogo pin. I would prefer a more solid power connection. I guess this could easily be added, though.
Up until now, I'm not so sure that they really care. They make no mention of the need to remove the 4 caps that we traditionally have to remove with the other similar style adapters already on the market. The implication is that this device is more advanced with a signal gain to compensate for it, but one would think that the caps should be mentioned. Here is the super clear response from tech support in regards to cap removal.
Call me fussy, but shouldn't the "testing" and "documentation" be done in advance by the manufacturer prior to final release? As usual, the customer pays to be the beta tester.
Some info and photos here:
https://info.mrtlab.com/notice/334.html
https://info.mrtlab.com/uploadfile/2023 ... 133741.png
https://info.mrtlab.com/uploadfile/2023 ... 544569.png
https://info.mrtlab.com/uploadfile/2023 ... 388981.png
The SATA redriver looks similar to this:
SN75LVPE802RTJR, Texas Instruments, Two-Channel 8 Gbps SATA Express Equalizer and Redriver, marking LVP802, QFN20:
https://www.ti.com/lit/ds/symlink/sn75lvpe802.pdf
The TTL-USB bridge is a CP2102.
CP2102, Slicon Labs, USB to UART bridge:
https://www.silabs.com/documents/public ... 2102-9.pdf
I don't understand what U7 does. :-?
There is a pushbutton switch (SW). I wonder if it shorts the read channel?
Edit: Yes, it does.
Convenient and independent TV9-TV10 circuit shorting button
I think U6 may be a 4-bit level translator for the UART Tx/Rx pins plus two others (?).
TXB0104QRGYRQ1, Texas Instruments, Automotive 4-bit bidirectional voltage-level translator with auto direction sensing and +/-15kV ESD, marking YE04Q1, RGY-14:
https://www.ti.com/lit/gpn/txb0104-q1
U11 would be an EEPROM for the CP2102 bridge - No, this wrong. U11 is a 10-pin IC.
That is a pretty detailed breakdown without having physical access to the board. Thanks for posting.
Here are photos of the 800069 equalizer PCB:
https://photos.app.goo.gl/f4hYtXuKbf8vdeTr9
They suggest that U3 and U5 are SN74LVC2G240 buffers.
SN74LVC2G240, Texas Instruments, 2-ch inverters with 3-state outputs, 1.65V - 5.5V, marking C04J, VSSOP-8:
https://www.ti.com/lit/gpn/sn74lvc2g240
U12 appears to be a TS5A3167 analogue switch.
TS5A3167, Texas Instruments, 1-channel analog switch (active low), 0.9 ohm on-state resistance, 5V, 1:1 (SPST), marking JATF, SOT23-5:
https://www.ti.com/lit/gpn/ts5a3167
U13 appears to be a 3.3V LDO regulator.
AP2112K-3.3TRG1, BCD / Diodes Inc, 3.3V LDO regulator, marking G3P, SOT-23-5:
https://www.diodes.com/assets/Datasheets/AP2112.pdf
U10 is a 12V-to-5V DC-DC converter. This IC supplies switched power to the HDD via the 12-pin connector.
AP62300WU-7, Diodes Inc, synchronous buck converter, 3A, 4.2V - 18Vin, marking HFywx, TSOT26:
https://www.diodes.com/assets/Datasheet ... 62300T.pdf
