DE & Long File Paths
It has been over 7 years since I first got MRT and in all these years, they have yet to fix a simple issue of their adding a long string of text into a folder that they insist on creating in order to save the selected data into. So, rather than just save Root or, better yet, just the selected contents of root into the target file path, we end up with this long mess which causes the file path of some data being saved out to exceed the 255 character limit.
Simple fix...don't create a folder path called "GPT partition - 931.51 GB > Partition 04 - NTFS - 921.80 GB - OS (273.69 GB) > Root" inside the target folder that the user selected to save their data.
And, as an add on, when the damaged files are selected to be saved to a separate folder, they too, should be saved with their full folder path without the extra garbage mentioned above.
ryangray
Re: DE & Long File Paths
Post by ryangray »
if you face any kind of problem with long path file or this kind of error simply use long path tool pogramme so that you can easily solve the problem, I think you would be able to get help with this
I've setup the registry to allow for long file paths, as per the link supplied by Franc. I hardly ever use MRT, so it may be a while until I have a case where I can test it out. The longpathtool seems to be an after the fact program, which would be useless after MRT completely butchers the recovery by saving all the long file path files into a common folder without any way to know where they should have been located.
