MRT 2182 Released
MRT 2182 Released
Download Page
November 22, 2022
MRT package:
1. Optimized and improved the device compatibility of MRT Express on Intel Chipset motherboards and reduce the chance of device status error
Note: Please be sure to install the new MRT driver file as administrator
Main program, upgrade to 2.1.8.2:
1. New menu bar "Announcement":
Visit the official website (CN:vip.mrtlab.com EN:vip.mrtlab.com/en/)
Visit the user center (CN:info.mrtlab.com EN:us.mrtlab.com)
2. Added announcement pop-up window on main interface, including now software upgrade notification and other notifications(such as tutorials, announcements). Single click "ignore notification", the effective period is 1 week
3. Optimized the soft/hard reset operation within a single read command cycle
ROM programmer tools:
1. Optimized the ROM programmer's strategy of reading and writing ROM, and added data verification by "block".
Western Digital:
1. Added new feature to disable and enable module 183 in ROM tools
2. Added a log to notify the status of module 183
3. Fixed the problem about failure to unlock PCB 810035. For version 2173 we need to choose 800022 to unlock 810035
4. Fixed the size error of the modules saved during resources backup
5. Optimized the dump T2 function without rebuilding T2 to mitigate unstable reading issue that occurred during data copy (Usually appeared when there are miss-aligned entries in module 190)
6. Optimized the search function of internal modules
Seagate, upgrade to 2.0.8.2:
1. Added A2 family UA and SA 4K option default configuration to avoid reading wrong system file size
2. Fixed the bug as to 97 family unlock failure
3. Fixed the issue about reading ROM error after bootcode mode recognizes the family under family interface
4. Fixed the error that there appears “Unlock failed” due to incompatible family when trying to unlock drives that belong to family 72
5. Fixed the software corruption issue that may occur when MCMT outputs log information
6. Optimized the unreasonable default configuration of some families
7. Optimized the default ROM size read by A0 family from 512 bytes to 1024 bytes
8. Optimized the preamp type display error of SAP information in ROM tool
DE module:
1.Added "Show only system drives" option in the device panel when creating task
2. Fixed the problem that some partitions cannot be analyzed and expanded
3. Optimized the LBA statistic algorithm to make it more accurate
