wd my cloud 1 disk encrypted
Discuss Western Digital hard drives, their issues and data recovery.
italyassistance
Post by italyassistance »
Hello i have this disk wd my cloud home 4tb one disk
in this disk there is structure ext4 and all files is encrypted
reading on forum i found this possible solution
https://community.wd.com/t/solved-my-cl ... /249403/23
but when i modify python script with imac
exit this message
Opening database.../rQuerying database.../rTraceback (most recent call last):
File "/Users/mariozottoli/Desktop/mycloud-restsdk-recovery-script-master/restsdk_public.py", line 70, in <module>
cur.execute("SELECT id,name,parentID,mimeType,contentID FROM files")
sqlite3.OperationalError: unable to open database file
has anyone already worked with the wd mycloud home and can you help me?
Re: wd my cloud 1 disk encrypted
The last unit I had was encrypted with LUKS. The client didn't pay attention to the message to save the key. The only way to recover the data was for me to fix the unit with my clone, load it up in the web interface, make the shares open to me on my network, then copy the files over the network to the new destination drive.
If you have the LUKS passkey, you might be able to recover from the clone using UFS Explorer, too.
I just looked at the link you sent and it seems like they are describing the setup where they use a SQL database to replicate the file system. This, too, is supported with the latest version of UFS Explorer.
italyassistance
Hi luke disk is perfectly, the problem is NAS when i go in web interface, disk is result offline, i have latest version ufs explorer but not decrypt files :(
italyassistance
where is the LUKS passkey?
Maybe a donor enclosure is the way to go?
italyassistance
ddrecovery what do u mean?
The underlying issue on one I encountered was the network settings went stupid. You can hold the reset button down on the NAS long enough for it to reset the network settings back to DHCP...that may be all you need.
italyassistance wrote: Wed Sep 16, 2020 5:11 pm ddrecovery what do u mean?
As Luke said, a reset or a new enclosure might solve it.
italyassistance
lcoughey wrote: Wed Sep 16, 2020 7:12 pm The underlying issue on one I encountered was the network settings went stupid. You can hold the reset button down on the NAS long enough for it to reset the network settings back to DHCP...that may be all you need.
if wanted use to ufs explorer,where colud i find luks key?
