Page 1 of 2
SSD Model, Controller, Issues and Recoverability
Posted: Thu Feb 28, 2019 8:07 pm
It seems that the list of unrecoverable SSD controllers is greater than the list of recoverable controllers. So, this thread is intended to be a log of SSD models, their controllers, issues and recoverability...and anything else that might be relevant.
Feel free to contribute.
Re: SSD Model, Controller, Issues and Recoverability
Posted: Thu Feb 28, 2019 8:15 pm
Model: 120GB SSD (yes, for real. Doesn't even have a label on the casing)
Controller: SM2258XT G AB
Symptoms: Detects correctly, but absolutely no LBA access
Solution: Not yet supported with PC3000 SSD. Recovering using custom methods.
- IMG_20190228_1458292.jpg (168.86 KiB) Viewed 247679 times
Posted: Fri Mar 01, 2019 4:54 pm
Model: 240GB SanDisk SSD Plus
Controller: SM2246XT H AA
Symptoms: Stuck at BSY and does not ID
Solution: Virtual translator. Reads about 2/3 of the sectors good.
- SanDiskSSDPlus-SM2246XT.jpg (93.11 KiB) Viewed 247666 times
Amendment, after reading at about 200KB/second for several days, we are only reading about 1/4 of the sectors, with 3/4 being unreadable.
Posted: Fri Mar 08, 2019 1:21 pm
Model: 128GB Kingston SMSM151S3/128GD
Controller: PS3109
Symptoms: No access to data
Solution: Virtual translator. Reads 1-3MB/sec with some bad blocks
- Kingston-SMSM151S3-128GB-mSATA.jpg (48.93 KiB) Viewed 247640 times
Posted: Tue Mar 12, 2019 5:44 pm
Model: 480 GB SanDisk Ultra II
Controller: 88SS1074
Symptoms: Gets stuck at BSY when trying to access
Solution: Not yet supported with PC3000 SSD or any other data recovery lab in the world, that I'm aware of
- 480GB-SanDisk-UltraII-88SS1074.jpg (176.46 KiB) Viewed 247598 times
Posted: Wed Mar 27, 2019 5:16 pm
Model: Intel 256GB SSD Pro 5400s Series
Controller: SMI N00K24
Symptoms: Comes ready, then goes BSY when trying to ID
Solution: No firmware support with PC3000, but readable with DE
- Intel-256GB-SSD-Pro-5400s-Series.jpg (248.38 KiB) Viewed 247504 times
Posted: Thu Mar 28, 2019 4:20 pm
Model: Samsung 256GB 830 Series
Controller: S4LJ204X01-Y040
Solution: Short to kernel mode. Use virtual ldr and generate virtual translator. Reads with bad blocks (~ 1/2% of sectors are unreadable)
- Samsung-830Series-256GB.jpg (127.35 KiB) Viewed 247496 times
Posted: Mon Jul 22, 2019 1:09 pm
Plextor PX-128S3C
Controller: SM2254G
Symptoms: Full ID, but BSY when accessing data
- Plextor.jpg (157.99 KiB) Viewed 247098 times
Posted: Thu Jul 25, 2019 1:27 pm
Model: 120GB Kingston SUV400S37/120G
Symptoms: Client and technician couldn't access the drive
Solution: Failing NAND, able to clone with DDI with lots of bad blocks, but most are readable with multiple long timeout passes.
- 120GB Kingston SUV400S37.jpg (59.88 KiB) Viewed 247041 times
Posted: Fri Jul 26, 2019 4:35 am
I wonder how many of these timeout related problems could be recovered with HDDSuperClone by adjusting the Timer Settings?
http://www.sdcomputingservice.com/hddsuperclone/manual
