Page 1 of 3
128GB SanDisk Monolithic SD Card
Posted: Tue Jul 24, 2018 1:01 pm
We were able to read this card using our Spider Board with our PC3000-Flash recovery system. Sadly, getting the dump of the internal NAND is the easy part.
Re: 128GB SanDisk Monolithic SD Card
Posted: Thu Nov 21, 2019 7:54 am
Ball park figure, what does the PC3000 Flash cost and what are annual costs? So I have something I compare with Flash Extractor. If you had none of them, which would you buy with your current knowledge?
Posted: Thu Nov 21, 2019 4:47 pm
I believe that PC3K Flash is around $2400 USD with annual updates for around $700. But, I could be off by a few hundred dollars. Basically, the up front fee is more than Flash Extractor, but the annual updates is much cheaper.
Posted: Sun Mar 15, 2020 10:45 am
Thank you Luke!
Posted: Mon Mar 16, 2020 3:31 pm
by ddrecovery
Joep wrote: Thu Nov 21, 2019 7:54 amIf you had none of them, which would you buy with your current knowledge?
I have all three of these products and here is my take on them all.
PC3K Flash:
Pros - It has an easily to understand UI and takes you through a recovery step by step.
Cons - If ECC and XOR is not in the database, then a chip is quite often unrecoverable. New chips not in the database cannot be set up easily.
VNR:
Pros - Can set up new chips, develop and extract ECC and XOR.
Cons - Can be confusing to use, you NEED a training class to understand it.
FE:
Pros - Extensive daatbases for ECC and XOR.
Cons - Poor UI, very slow support.
Hope this helps Joep.
Posted: Mon Mar 16, 2020 7:38 pm
Definitively! Thanks Luke! Thanks Tim!
Posted: Tue Mar 17, 2020 12:05 pm
If your goal is to just get the NAND dumps to play with, buying the Flash Extractor NAND Reader is pretty cheap and doesn't require a full license to get the dumps. But, in order to run the app to piece them together and recover the data, you'll need the license.
Posted: Wed Oct 16, 2024 2:36 pm
by italyassistance
Honestly I think that the spiderboard has little efficiency I use it but using the needles is complicated and you have to be very careful because they easily move and can damage the monolithic, what do you think?
Posted: Wed Oct 16, 2024 3:48 pm
Yeah, I find the spiderboard needles too large, causing some serious gymnastics to be needed in tight spaces...and it does scare me that a simple slip can cause some pretty nasty damage.
Posted: Wed Oct 16, 2024 4:26 pm
by ddrecovery
Also the spider board doesn't tell you if you don't have a connection. ie it will tell you if there is a short on a connection, but if you have missed a pin, it will still say the connection is good and show it as green.
