First Responses before, during, after OS or Data loss crises.
RolandJS
Post by RolandJS »
** Those with Dynamic, RAID, SSD, or 3GB+ setups -- seek advice from those specialists. **
A few good "first responses" PRIOR to any OS and/or Data loss crisis
AND
A few good "first responses" AFTER any OS and/or Data loss crisis
-- using Macrium Reflect, AOMEI Backupper, EaseUS Todo, or anything similar, free or pay-for:
---- routinely make full image backups of one's OS and Data onto affordable and reliable external media; or
---- routinely make a clone of your OS and Data hard-drive onto another reliable hard-drive
---- make usb and dvd boots with your backup/restore utility of choice
[if no cd/dvd device in laptop, if affordable, get a usb cd/dvd device]
During any of the following situations, these three first responses may be best:
1) chill 2) breathe 3) chill
During any file or files deletion loss
If Windows works, if Recycle Bin works - check for any deleted file(s) you want to un-delete.
If Windows works, if you have a 3rd party un-delete program, check that bucket.
During any Windows not working crisis
If no Windows,
OR
During any partition(s) not found crisis
If no partition(s),
Boot backup/restore/cloning utility usb or dvd,
[if no cd/dvd device in laptop, if affordable, get a usb cd/dvd device] and:
-- if possible, make a one-pass DIY clone onto an external HD; or
-- if possible, make a one-pass DIY full image of the hard-drive onto any affordable and reliable external media
-- wait patiently, in whichever forum you're in, for expert advice and help; or
-- if affordable, take it to a local computer fix-it place/specialist and let him/her help you; or
-- if affordable, if possible, send the hard-drive to a data recovery place
During any hard-drive not found crisis
If no hard-drive access, it's mostly either a physical failing or a "logical" failing
There is a fork in the road, you choose which tine, which path, you believe is best --
1) Boot backup/restore/cloning utility usb or dvd,
OR
Making a DIY one-pass clone or full image means:
-- the process reads or tries to read each sector only once, there is no re-reading, re-trying any sector
-- the process is started and run, without interruption, to completion
-- when the process "says" it is finished, it is finished and the 2ndCopy HD is put away for safe-keeping
-- if the process interrupts itself at any time or point, the process is finished, the 2ndCopy HD is put away
AND
-- wait patiently, in whichever forum you're in, for expert advice and help before continuing; or
This is as far I can go for this article. I'm hoping data restoration and data recovery specialists
will weigh in with their advice and practicals in future articles.
If you want to see snippits, elsewhere-posted comments of data recovery folks far wiser than I,
gathered from across The 'Net, see my itty bitty place's backup,restore...thread.
Re: First Responses before, during, after OS or Data loss crises.
To be honest, I find this post rather confusing and suspect that what you are trying to explain is how to triage a hard drive without making data loss worse.
RolandJS
Post by RolandJS »
lcoughey wrote: Fri Apr 21, 2017 7:09 pm To be honest, I find this post rather confusing and suspect that what you are trying to explain is how to triage a hard drive without making data loss worse.
This is my first attempt at setting up some ideas and practicals for new computer users, common computer users. Technicians and specialists have no need for this thread :)
And, I like your link so well I placed it into my college cafe's Computer Technologies forum, along with your blog URL.
