files pdf are corrupted afet recovery
A place to post photos of data recovery disasters and to discuss unusual data recovery cases.
zendou
Post by zendou »
hi
i dont speak english (my inglish is bad) excuse me
this is my probleme:
after cloning my partition , the operation of cloning was interrupt ( broken) andi lost all my partition , i lost my VDI files it contain my pdf files.
I try many recovery software but always pdf are corrupted
help me please
thanks
Re: files pdf are corrupted afet recovery
How were you cloning your partition from what to what? Your recovered files are likely corrupt because you haven't copied their entire contents.
You should start by cloning the drive with ddrescue or some other software that can handle and log bad sectors.
Once you get a solid image of the drive, you can then attempt software recoveries with various data recovery programs.
If you are over your head, you might want to consider sending the drive to a data recovery professional. We may be able to assist remotely, depending on the root cause of issues and your technical abilities.
