ST2000DM001 Head Maps
We have 4 "identical" Seagate DM series drives from a NAS unit that one would think are identical internally, but they are not. So, I thought I might start listing drive specs as I encounter them to help with sourcing suitable donors:
Serial: W1E3...
Model: ST2000DM001
P/N: 9YN164-505
FW: CC82
Date: 13375
Site: WU
Number of heads: 4
Serial: W1E3...
Model: ST2000DM001
P/N: 9YN164-505
FW: CC82
Date: 13367
Site: WU
Number of heads: 4
Serial: W1E3...
Model: ST2000DM001
P/N: 9YN164-505
FW: CC82
Date: 13367
Site: WU
Number of heads: 4
Serial: W241...
Model: ST2000DM001
P/N: 9YN164-505
FW: CC82
Date: 13367
Site: WU
Number of heads: 5
Re: ST2000DM001 Head Maps
Just goes to show why the serial is important to check. I guess in this case the "2" must highlight the extra head. Probably was supposed to be a 3Tb, but had a platter surface that didn't pass QC.
What was the head map of that one anyway?
Another easily confused head mismatch:
Serial: W1E3...
Model: ST2000DM001
P/N: 1CH164-302
FW: CC26
Date: 13371
Site: WU
Number of heads: 4
Serial: W1F2...
Model: ST2000DM001
P/N: 1CH164-302
FW: CC26
Date: 13371
Site: WU
Number of heads: 6
Serial: W1E5...
Model: ST2000DM001
P/N: 1CH164-515
FW: CC47
Date: 14036
Site: WU
Number of heads: 4
Without checking the serial numbers, one would have thought that the first two drives would be a perfect match, but that is clearly not the case, leaving the first and third drives as having the more likely set of compatible heads.
I believe the 2nd and 3rd characters of the serial number should match, which they do for #1 and #3.
LarrySabo wrote:I believe the 2nd and 3rd characters of the serial number should match, which they do for #1 and #3.
Exactly, but not necessarily a guarantee that they will be compatible. But, at least they have the same number of heads.
It would be good to know how the slider topology, HSA sticker and HDA sticker relate to compatibility (preamp type and version). Not that you can check/know all of these on potential donors you don't yet own.
