Log of Seagate DM Series Issues
Re: Log of Seagate DM Series Issues
Model: ST3000DM001
P/N: 9YN166-500
FW: CC4B
Site: SU
SN: W1F
# of heads: 6 (0,1,2,3,4,5)
Symptom: thrashing, staying BSY and no ID
Cause: damaged firmware, bad sectors and dead head 4
Solution: disabled media cache, changed heads
Model: ST3000DM001
P/N: 1CH166-570
FW: CC83
Site: TK
SN: Z1F
Symptom: a couple clicks and spins down
Cause: damaged heads
Solution: change heads
Bruno
Post by Bruno »
Model: ST2000DM001
P/N: 1CH164-501
FW: CC24
Site: TK
SN: Z1E
# of heads: 4 (0,1,2,3)
Symptom: In accessible drive
Cause: corrupt glist, head 0 has read issues, bad sectors
Solution: cleared glist
Model: ST2000DL003
P/N: 9VT166-302
FW: CC3C
Site: SU
SN: 6YD
Symptom: does not even try to spin
Terminal Error: DTC Init (or) Training Failed
Fix: Saved ROM and wrote to donor PCB
Model: ST3000DM001
P/N: 1CH166-571
FW: CC43
Site: WU
SN: W1F
Symptom: Inaccessible Drive gets stuck at BSY
Cause: Damaged glist, Head 2 has some slow downs and read errors
Model: ST1500DM003
P/N: 9YN16G-302
FW: CC4C
Site: SU
SN: S24
Date: 12356
# of heads: 5 (0,1,2,3,4)
Symptom: Thrashing and Spins Down
Cause: Fatal Head Crash
Solution: Unrecoverable, DOA
Bruno
Post by Bruno »
Model: ST2000DM001
P/N: 9YN164-500
FW: CC4B
Site: SU
SN: W24
Symptom: goes busy while accessing sectors
Cause: damaged glist, bad sectors
Model: ST2000DM001
P/N: 9YN164-500
FW: CC4B
Site: TK
SN: Z1E
Cause: fatal head crash, rings etched into the platters, filter filled with debris
Solution: unrecoverable
Model: ST2000DM001
P/N: 9YN164-570
FW: CC9C
Site: SU
SN: S2F
# of heads: 5 (1,2,3,4,5)
Symptom: Clicking
Cause: Fatal head crash
Solution: D.O.A., Unrecoverable
Model: ST2000DM001
P/N: 9YN164-570
FW: CC9C
Site: SU
SN: S24
Symptom: Clicking and not accessible
Cause: Weak/Crashing Heads
Solution: Mirrored 93%, mostly with head 2 off in the latter part of the drive
