HI Luke,
Great post.
I had also successful experience with the following drive:
WD Zephyr - WD5000BMVW-11AMCS2
Platters were not 100% aligned and i got all the data from this drive.
Cheers,
Oded
Platter Swap Without Alignment Issues
Re: Platter Swap Without Alignment Issues
Thanks...list updated.
Confirmed today with a Zephyr as well.
Top platter scratched, removed for inspection, put back and works fine (except the top surface
- ddrecovery
Had to do a platter swap on a drive run over by a car, but I did not split the patient platters I moved them as one unit. However putting the donor platters back in the donor HDA after recovery, I misaligned them by about 1/16th of an inch on purpose (from my previous sharpie marks). Drive read from all platters without an issue.
Hitachi HDT547564A9E384 - 2 platters/4 heads - All surface reading with intentionally misaligned platters.
So much work keep them aligned and then you messed them up?? hahahahah
Good work and thanks for sharing.
Nice one Tim, good to know.
Tested today a TOSHIBA MQ01UBD100, moved around the top platter and it works fine.
- ddrecovery
Toshiba MK5061GSY - 2 Platters - 4 Heads.
Used HDA after a spindle motor failure.
Put platters back in donor and spun top platter 180 degrees.
All heads are reading 100%.
Hi guys,
ST2000LM003 family: M9T (BP) 3 platters, stuck motor (caution: not every motor will be compatible), random platter alignment, heads are reading full speed
ST750LM022 2 platters, quite precise platter alignment by marker on the edge, different headsets are reading with errors, speed 4-7kB/s, not recommended
Regards,
Dawid
Regards,
Dawid
