On that Samsung HDD, I managed to get those 2 bad blocks back from the void. So clearing the G-List does work as expected.
NOREWRITE appears to work...
  |                                  Events                                  |
  | Sector 8,705 (0.0017%) This sector could not be completely recovered     |
  | and 'NoRewrite' prevents its partial recovery and/or repair.             |
  | Sector 8,706 (0.0017%) This sector could not be completely recovered     |
  | Sector 8,707 (0.0017%) This sector could not be completely recovered     |
Oh dear...
  | Sector 48,960,716 (10.0247%) ALL DATA was completely recovered from      |
  | this damaged sector.                                                     |
  | Sector 48,960,728 (10.0247%) ALL DATA was completely recovered from      |
  | Sector 48,960,874 (10.0248%) After a minor problem reading this sector   |
  | occurred and a repeated attempt succeeded, this sector has been          |
  | re-written.                                                              |
CrazyTeeka wrote: Sun Apr 07, 2024 8:21 pm NOREWRITE appears to work...
  |                                  Events                                  |
Oh dear...
  | re-written.                                                              |
That's without a doubt SpinRite's most useful feature then.
Shame it does not stop re-writes when bad sectors can be read successfully. But it's a step closer towards doing the right thing.
We think we got the data from this bad sector 100%. Don't worry, even if we didn't, it is unlikely you will ever notice.
SR gave this drive a good pounding, lots of stuff added to the G-List, it's taking a while to clear it.
Aborted. Was taking far too long. Think SR broke the drive. :roll:
Drive still reads but...
Why does "Format Unit" no longer complete?
Why does "Clear G-List" no longer complete?
WD2500BJKY-75F4T0
CrazyTeeka wrote: Tue Apr 09, 2024 3:38 pm SR gave this drive a good pounding, lots of stuff added to the G-List, it's taking a while to clear it.
WD2500BJKY-75F4T0
It would be very useful if you can carefully document this.
Joep wrote: Wed Apr 10, 2024 10:37 am It would be very useful if you can carefully document this.
Timeline of things done to Drive
1st run of SR on level 2 really struggled, drive went offline and stopped responding to RESET commands.
1st run of "Format Unit" completed.
1st run of "Clear G-List" completed.
2nd run of SR on level 2 appears to struggle less, but lots of bad sectors near start of drive. Starting 1% in seems to work better.
2nd run of "Format Unit" fails to complete. Should take around 58-60 minutes, but still running after a few hours.
2nd run of "Clear G-List" fails to complete. Should take around 1 minute, but still running after a few hours.
More to follow...
https://forums.grc.com/threads/drive-ke ... post-11908
"It's not SMR!"
Steve Gibson keeps babbling about SMR ..
What clown!
Model Family:     Western Digital Scorpio Black
Device Model:     WDC WD2500BJKT-75F4T0
Serial Number:    WD-WX10A8920970
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   001   001   051    NOW  23751
  5 Reallocated_Sector_Ct   PO--CK   128   128   140    NOW  573
Screenshot 2024-04-11 105903.png (32.12 KiB) Viewed 59352 times
