UFS Explorer Professional Updates
Re: UFS Explorer Professional Updates
What's new in version 7.9:
* Added support of DeepSpar image file format (DDI, including defect block maps);
* Added Virtual Pattern storage for construction of over-degraded RAID;
* Added function of converting span of sparse components to sparse virtual disk;
* Added function to open base files of sparse virtual disks for fine-tuning of VD container;
* Added function to open disk as virtual disk for full-disk clones of virtual disks;
* Fixed problem with recognition of BitLocker when recovery key comes with version not equal to 1;
* Fixed bug with BitLocker "plain key" format;
* Fixed bug applying delta files in format of Split-VMDK;
* Added option to apply masks to folders for copying with filter;
* NTFS tail processing is now included into quick scan (to file system indexing).
Iurii wrote: Wed Jul 03, 2019 5:35 pm What's new in version 7.9:
Can someone explain exactly what this means.
ddrecovery wrote: Wed Jul 03, 2019 6:43 pm Can someone explain exactly what this means.
Hi,
This mean you may add one or more "Virtual Pattern" storage to RAID. You may create such storage via menu "Open" -> "Virtual Pattern" storage
Set size, name and pattern. It may be added to any RAID for further processing.
It may be useful for some scenarios with missing drives. I.e. if you have RAID 0 with one missing drive and you need to get at least something with report of bad files.
What's new in version 7.10:
* Support of 'long' deduplication reparse points on NTFS (Windows Server 2019);
* Fixed bug reading files from Microsoft Deduplication Database in some scenarios;
* Fixed bug reading directory structure of latest ReFS3 file system;
* Apple Core Storage: fixed crash bug, added block reference type "16";
* Added search for BitLocker partitions to Partitions Manager;
* Added BitLocker indication to Partitions Manager;
* Major rework of NTFS scan procedure:
- Added old/duplicated objects removal from scan result;
- Better processing of lost files (with descriptors out of MFT);
- Changed priorities of file names processing;
- Fixed bug in folder structure recovery by INDX entries;
- Fixed bug with scan resumption and calling Recycle Bin processing;
- Added support of Recycle Bin indexes with version 2.
* Added Portuguese software interface language.
Iurii wrote: Tue Jul 23, 2019 10:39 am * Added search for BitLocker partitions to Partitions Manager;
This will be a nice feature when the need arises.
What exactly does this mean?
What's new in version 7.11:
* Added support of DeepSpar DDI over network;
* Added to Apple Core Storage:
- Plain blocks, reference type 11;
- Support of compressed multi-block XML metadata.
* Added 'Pause' function to file copying procedure:
- Quick pause/resume for temporary 'releasing' disk;
- Option of finishing current file and with ability to change destination path.
* Support of NTFS with cluster size over 64KB;
* Support of Windows Server 2019 Storage Spaces metadata;
* Added cluster size indication to file system properties;
* Fixed bug using 'Open' dialog with scan results of virtual disks.
What's new in version 7.12:
* Added support of WD Cloud file system:
- Translation of Cloud database to file system structure;
- Support of main database or backup copy (on choice).
* Added parallel data visualization in RAID builder:
- Synchronized with hexadecimal data viewer;
- Automatic reconstruction of missing data (when available);
- RAID pattern visualization;
- Automatic parity check (when available);
- Highlighting of key structures (such as MFT).
* Button to show/hilde left (storages list) panel;
* Added support of defect blocks in format of ACE Data Recovery MHZ;
* Now saves RAID configuration when sector size transform is enabled;
* Fixed some issues and speed-optimized ZFS file system scan;
* Fixes to Btrfs file system support:
- Fix of crash bug during scan in some scenarios;
- Fixed reading of compressed files.
* Update to PDF viewer: added support of buggy files with shifted xref table;
* Added extra search for folder name entries for EXT file system;
* Fixed bug reading legacy HFS volumes;
* Added Spanish software interface language.
What's new in version 7.13:
* Added "Dynamic HTML Report":
- interactive navigation on file system structure;
- interactive file search function;
- interactive report conversion to XML/CSV format;
- files/folders selection from report;
- reverse import of selection state to UFS Explorer/Recovery Explorer.
* Extended basic XML/CSV reports with ID/parent ID to preserve FS structure;
* Added search for LUKS partitions in partition manager;
* Fixed bug reading BitLocker volumes on drives with 4K sector size;
* Update to Windows Server 2016/2019 data deduplication:
- Fixed several bugs related to reparse point formats;
- Fixed bug processing files with size over 1GB.
* Significantly reduced number of storage reads during file systems detection;
* Extended 'normal' detection of NTFS, FAT32, HFS+ and EXT volumes using backup metadata;
* Fixed reading of Windows dynamic disks with GPT layout;
* Option to skip found regions during partition search for faster scan.
I can't wait to download and use this new version. Thanks for listening to your user base?
What's new in version 7.14:
* ZFS direct access:
- Fixed bug in double-degraded RAID-Z2/Z3 recovery;
- Added support of RAID-Zx0 (stripe of RAID-Z/Z2/Z3);
- Added support of SunOS-specific "long" allocations on RAID-Z;
- Fixed several bugs in metadata parser procedure.
* Dynamic HTML report:
- Fixed problem with JavaScript integer precision for big object IDs;
- Report with filter is now displayed with minimal required folder structure;
- HTML styles corrections.
* Microsoft data deduplication support is now available in quick scan;
* Added support of VMware seSparse VMDK;
* Enhanced raw recovery procedure for MPEG Transport Stream (MTS/M2TS) files;
* Fixed bug with "filter" function ("must match"/"must NOT match" pattern).
