Hello,
Need resource for WD3200BKET-75VMT1
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok
SA regions address...................... : by default
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 04.2DK
ROM F/W version......................... : 0004002D
Overlay F/W version..................... : 04.2DK
Servo F/W version....................... : 02.0E
Heads configuration..................... : by map
Heads number............................ : 2
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
Thanks In Advance
Need LDR for WD3200BKET-75VMT1
Re: Need LDR for WD3200BKET-75VMT1
I assume you mean WD3200BEKT-75PVMT1 ?
I've got ROM versions:
00040011
00040022
00040027
but no 0004002D
00040011
00040022
00040027
but no 0004002D
Sorry Its WD3200BEKT-75VMT1
Really? No letter P in the part after the dash, that's strange. It must be a model I've never run across.
Extremely sorry ,You right,please find attached pic
- Attachments
- IMG_20151230_101545.JPG (81.9 KiB) Viewed 13499 times
Ah, as I suspected. As I mentioned I have those other ones, but not the version you're looking for. You can probably use one of them along with the corresponding ROM code to at least read the tracks, then extract the proper module 11 from there. I've had to do that quite a number of times.
You can get any of them yourself on my firmware server: https://www.data-medics.com/forum/firmw ... s-t28.html
Sorry...I finally had a chance to check and we only have with firmware T0. Did you try contacting donor drives to see if they have it?
