JPEG Photo Repair
Ris Victoria
Re: JPEG Photo Repair
Post by Ris Victoria »
Do you agree that some corrupted JPGs just can’t be fixed at all...a while back i had the "windows photo viewer can't open this picture because either photo viewer doesn't support this format” problem...i tried literally everything! But nothing would work :?
Ris, are you sure that the contents of the file is actually JPG data? Sometimes people recover overwritten files and wonder why they are corrupt and not repairable.
Perhaps the full story would help us better answer your question.
Agreed, "tried everything" equals zero relevant info. And yes, of course some JPGs can't be repaired. It becomes less likely with each bit of info corrupt/lost that it can be repaired.
Junepablo
Post by Junepablo »
Great programming that did what I needed which was to recoup some adulterated jpg documents of much adored photos using JPEG Repair Tool - [spam link removed]
Exceptionally appreciative!
Moderator Note: Once again, Stellar spamming forums with their sub-par software and horrible grammar.
Ushavilash
Post by Ushavilash »
lcoughey wrote: Thu Mar 24, 2016 6:58 pm Although I haven't had a lot of success with this program, I can see how it could be useful in the right circumstance.
Certain broken JPG can be fixed, but some may be too damaged. Use trusted software or services made for fixing and recovering photos. Avoid regular compressors because they can make the picture worse. Many images get damaged when compressed with the wrong algorithm. I suggest using this JPEG Compressor tool for better results.
