Hi!
I have 2 doubt and 2 problem at the same time.
Selected family:MQ04ABF100
Model:TOSHIBA MQ04UBF100
Load Zones : .........................:OK
Cyl Num : ............................:393620
Head Num : ...........................:2
Vendor : .............................:TOSHIBA
Model : ..............................:MQ04ABF100
Microcode : ..........................:JU002U18
I made usb to sata, it was perfect but...
I cloned 80% of the HD with the function:
"ECC ERROR IGNORE ON" Enabled...
Could this cause sectors to be read the wrong way? Corrupted?
Thank you for the opportunity to post on this forum.
"ECC ERROR IGNORE ON" Enabled... MQ04UBF100
- 1mq04.png (93.04 KiB) Viewed 5280 times
Re: "ECC ERROR IGNORE ON" Enabled... MQ04UBF100
1. Does the drive not read without ignoring ECC?
2. Can you see a file tree and open files in DE?
